RTX 4090: Multiple Monitor Configurations
Solved by Blai5e,
@SimpleCast - well, I have 2 x 4k 160Hz monitors and sometimes I hook both up to my 4090 (via DP1.4) and they both run at the advertised 160Hz using Display Screen Stream Compression (DSC), so I don't see the issue with three monitors. Well... maybe trying to push that many pixels (3 x 8,294,400 = 24,883,200 pixels) might limit the achievable framerate.
