Best SILENT fans for PC cooling?
Your system includes an hdd. If that isn't too noisy for you and you aren't replacing it and only using ssds, you might not notice the difference with some cheaper fans.
1x NF-S12A rear exhaust and 2x Kaze Flex 140mm front intake works well:
https://pcpartpicker.com/product/cgqBD3/scythe-kf1425fd12s-p-672-cfm-140-mm-fan-kf1425fd12s-p
If cost isn't an issue and you're racing towards as quiet of a system as possible or best cooling at a fixed noise level, NF-A12x25's or T30's would be the best. 3x front intake and 1x rear exhaust:
https://pcpartpicker.com/product/zxx2FT/noctua-nf-a12x25-pwm-601-cfm-120mm-fan-nf-a12x25-pwm
https://www.amazon.com/dp/B09B2LNFV4
T30's would perform better but not be as quiet at very low rpm.
1x T30 rear exhaust and 2x Silent Wings 4 140mm front intake is also an excellent option: https://pcpartpicker.com/product/fXcG3C/be-quiet-silent-wings-4-784-cfm-140-mm-fan-bl097
