How do Y-splitters work with PWM connectors on Motherboards?
They work by getting the PWM signal from the first fan that uses all 4 pins. After that it just assumes they're all the same speed and sends the same pwm speed to all the fans.
The only thing to be aware of with them is to not go over the amperage rating of that header on the motherboard
ViciousRaptor ·
Posted in Troubleshooting2 -
KennethC90 ·
Posted in Cases and Mods0 -
ComputerOuchies ·
Posted in Troubleshooting0 -
EzioWar ·
AdityaSaraf ·
Posted in Displays2 -
gooseta ·
Posted in Troubleshooting5 -
Dareios-Gintoki ·
Posted in Troubleshooting7 -
1
220VoltsallCore ·
Posted in Displays10
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
