help me fix my gpu temp and fan noise (RX 580 8 GB AUROS)
Solved by WoodenMarker,
15 hours ago, Pakwarrior said:nope guide me
You can undervolt through AMD Radeon Software. In the software, go to Performance > Tuning > Tuning Control > Set from Automatic to Manual. GPU Tuning > Set to Enabled. Advanced Control > Set to Enabled.
You can lower the State7 (Max) voltage to a lower value like 1100mV and click Apply Changes. You can test stability with a stress test like FurMark and / or some games.
If there are no issues, you can try incrementally lower the voltage to values such as 1090mV or 1080mV and test again. If there's any sign of instability, you can raise that value back up to something more stable. Once you settle on the lowest stable voltage, you can lower the other state voltages so they aren't as high as State7 (Max).
