artificial intelligence I need help to build a pc on low budget: Artificial Intelligence generated visuals (like Stable Diffusion, VQGAN+clip etc)
Solved by igormp,
30 minutes ago, Fracteller said:Will a cheap CPU like Intel Core i3-12100F bottleneck the 3090 for Artificial Intelligence visuals?
No, the CPU is pretty irrelevant for that.
30 minutes ago, Fracteller said:Is 8 gb DDR4 Ram enough ?
Depends on what you're trying to do. For SD only it should be enough.
30 minutes ago, Fracteller said:Is the Gigabyte H610M S2H motherboard enough? (I think it is)
Yes.
However, why don't you just buy an even beefier PSU and have both the 4090 and 3090 in the same PC?
