can my 500 watt power supply support a rtx 3060
 Share
i want an rtx 3060 12gb so i can use dlss for a 4k monitor can my 500 watt psu handle the power requirements for one?
What model 3060? What else is in your PC?
Generally the 3060 recommends 550W.
the 12gb model cause i want to double my vram from 6gb with my currentl 6gb vram 1660 ti to a 12 gb 3060
all 3060 is 12GB. And its not suitable for 4K gaming despite having 12GB Vram
If you want me to answer, please use the quote function or tag me. I dont get notified unless you do
my 1660 ti is a 1080p king double that and you get 4k i could definetly do 4k with a 3060
Your 500W is too small.
You're going to need 550W.
what will happen if i try using my 500 watt psu?
4K is 4 times 1080p, not 2
under 50FPS sounds like a winner to me
what about games with dlss?
Sure, DLSS will help, but then you are not actually playing in 4K. DLSS renders the game in a lower resolution(1440, 1080p etc.) and upscales it to 4K
Can your psu actually deliver 500w? Make and model?
15 1360OK | Z690-A Wife | Thermotake 16 GO SODINM(2 of them) | 1TB m.2 ssd card + 2TB SATA nvme | RTX3060 Ventus duel fan 12 GBi | NZXT H510 Elite | Seasonice 600watts voeding
i dont have to play the games at the maximum settings to achieve 4k60fps
its a evga 500 watt power supply
What 500w psu is it? Make and model
4k is 4x the pixel of 1080p. 4k medium 60 is achievable but thats about it.
Sure, I just dont get the logic here. Its like building a really fancy double garage to only using it for a Nissan Micra.
The 3060 is a excellent card for 1080p and its good in 1440p, but I wouldn't buy it if the argument its for 4K gaming. For that I would at least save up for a 3070 class card, dont be deceived by the 12 GB of VRAM
which game is that?
which game is that?
A generalization. What games will you be playing?
Also what make and model of psu is it.
Evga 500w means nothing as they have quite bad psus like the w1 which wont handle a 3060 well
i heard the gtx 1080 ti can play 4k games when games around its time was released like 4k fallout 4
Sometimes...it's hard for people to understand where they can find that.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
1) At best minor stuttering, freezes, glitches, crashes, BSODs and boot up problems.
2) At worst damage to psu, ram, mobo and gpu (been there).
Things listed in 1) may happen after few weeks of seemingly normal performance, but since you want to just dive into demanding gaming your psu will have to work under full load and still will not meet minimal requirements. In my, budget and tested, opinion it is far better to buy cheaper but more powerful psu (ie: 700-1000W) and have plenty of room and utilize unit at 60% then having high end one and barely having any room, ie recommended 550W psu. I'd totally go for 700W or bigger unit.
my current pc specs are an 8700k cpu 1660 ti gpu 32gb of ram
Check your supply against the tier list. If its decent quality, then simply try it.
A good PSU, if overloaded, will shut down gracefully.
I run a CX550M with a 3060Ti and overclocked 4930k with zero issues.
Yeah, and 1660 TI would run on 350W, I got 6600XT and am on 700W psu having 100W of room. Like I said, for 3060 I'd go for 700-1000W psu
This is just the usual nonsense that gets perpetuated around PSUs. A 1660TI draws around 120w. The 3060 draws around 170.
So if a 1660ti is happy on a 350w PSU, why would a card that draws 50w more suddenly require a 700w unit?
A 3060 is not a power hungry card and 500w is plenty, so long as its a quality 500w unit and not trash tier.
If you put a 1080TI in that machine, you won't be happy with 4K experience.
4K/60 at low/medium isn't near as fun to play a game as 1440p/60 High or 1080p/120 Ultra.
4K doesn't mean shit, but they are successfully brainwashing folks it seems.
TBD - AMD Ryzen 7 7700x - MSI 6900xt Gaming X Trio - Gigabyte B650 Aorus Pro AX - G. Skill Flare X5 DDR5-6000 32GB - Samsung 980 1TB x3 - Super Flower Leadex V Platinum Pro 850 - ON THE WAY: EK-AIO 360 Basic and ThermalTake Core P3.  Looking forward to building week of Dec 5th.
Emma : i9 9900K 5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200Mhz - 750 EVO 512GB + 2x 860 EVO 1TB (RAID 0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Corsair Virtuoso SE - Logitech G910, G502 - Cooler Master Universal Graphics Card Holder
Plex : Ryzen 5 1600 - Gigabyte B450M-DS3H - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1900 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Samsung 27" + Dell 24"
Raven:  Intel i3 10100F - ASRock H410M-HDV - G. Skill Ripjaws V 16GB 2666Mhz - MSI 1050Ti 4GB - Inland 256GB SSD + Toshiba 2TB HDD - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Spectre 24"
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM, 512GB NVMe SSD, 1050Ti, 4K touchscreen
MSI GF62 - i7 7700HQ, 16GB 2400 MHz RAM, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti
 Share
