cord for cooler master cm storm laptop cooler unit
RamseyM.D.
I lost my cord for my old above unit, which I love.  who do I go to to order another cord.?
This: https://www.coolermaster.com/catalog/coolers/notebook-cooler/sf-17/#image-Item5 ? Uses a mini-USB 5V input. If you need a new cord Amazon should have them for cheap, phone chargers are gonna be 5V so you can just use one of those, or it may power off the laptop itself, I haven't used one of these before.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
It will, it only draws 250mA when the fan is at max and the least that USB ports give out nowadays is 500mA, so twice what the thing needs... I am running such a laptop cooler for my gaming laptop too (not this exact model, one with pretty loud fans) and it has a USB cable attached with data passthrough so that you don't lose a port when it's plugged in
