Is it safe to use PC without Case Fans?
NerdIsHere
My Case Fans Broke it's going take 1-1.5 weeks to arrive new case fans
so Is it safe to use my pc without case fan for a while?
Sure. You might see a bit of a temperature rise. But your PC should be okay until you get the new fans. Just make sure your computer has at least some airflow and you didn't burry with a blanket haha-
All of the fans are broken?
If so, for really high powered parts, it could be rather bad, you never know if anything is faulty and only gets triggered with extremely high temps.
But for mid or lower tier parts, might be just fine, tho temperature would be a lot hotter, worse case scenario just thermal throttling, barring faulty hardware.
Anyway, just take off the side panel in the meantime and be extra careful around your pc.
And why would a replacement fan take a week...
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI MSI PRO B760M-A WIFI DDR4
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
I only have 2 fans (one was broke few days ago and final one broke today)
cuz i live in third party country
depending on the specs it might run rather hot very fast, but it'll work.
if you dont have kids or pets running around to worry about, just leave the sidepanel off until you have fans.
You're probably fine but might see higher temps or worse performance. Modern components are usually smart enough not to fry themselves. I briefly ran with no case fans without knowing it after I upgraded my motherboard and forgot to reconnect them. It was still usable and I didn't even notice a drop in frames because I was GPU bound anyway. A fun side effect was the top of the case right above the CPU got quite warm, which my cat thought was a great place to sit.
Main rig:
CPU: AMD Ryzen 9 5900X
GPU: Sapphire RX 6800XT
RAM: 2x16GB DDR4
Motherboard: Asus ROG B550-I
Storage: 2TB Samsung 980 PRO NVMe, 4TB WD Blue HDD
PSU: Corsair RM850x
Case: Fractal Torrent Nano
OS: Linux Mint 20.2 Cinnamon
NAS:
CPU: AMD Ryzen 4600G
Motherboard: ASRock Rack X470D4U
RAM: 2x16GB DDR4
Storage:
  • Boot: 16GB Supermicro SATADOM
  • Pool 1: 2x6TB WD Red Plus HDD mirrored, for bulk storage
  • Pool 2: 2x500GB NVMe SSD mirrored, for apps like Plex and Adguard Home
PSU: Be Quiet SFX-L 600W
Case: Silverstone CS351
OS: TrueNAS SCALE
To answer this 100% we'd need to know your specs, case and roughly ambient temp.
However. If can be done safely (if no animals or small children can enter the interior), remove your sidepanel and use Hwinfo or similar to monitor temps. Most likely will be fine but you may see degraded performance as have been mentioned earlier.
