(URGENT HELP NEEDED) New CPU cooler for AM4
Solved by LapsedMemory,
19 minutes ago, YuNii said:Thank you for the help already!!! My boyfriend went and figured out what my motherboard is while blowing a big fan at my motherboard so it (hopefully) doesn’t heat up too fast. According to hwinfo64 my motherboard is a “MSI B450-A PRO MAX (MS-7B86)” sorry guess I misremembered the brand.
Your Noctua will work just fine.
In your case, there's a 4-pin header up near your ram that is labeled CPU_FAN1. Plug the Noctua into there.
