Best vacuum cleaner for matresses?
MS-DOS
You know one of these machines that are handheld like the Hoover UltraVortex.
https://www.allergyuk.org/our-services/allergyuk-products/hoover-ultramatt-ultra-vortex/
I see Jimmy (not sure if related to Xiaomi) has the BX7 Pro one with better specs (stronger suction, goes 60ºC)
Lake-Jimmy-Instrumento-de-eliminaci-n-de
https://www.jimmy.eu/anti-mite-vacuums/121-bx7-pro-anti-mite-vacuum-cleaner.html
but I would like to know if there are some alternatives. Im also not sure about the UV, I like the idea that this helps cleaning but since it may emit ozone I would need to know this was properly tested and ideally not made in China but I guess that's too much to ask nowadays geez. There's a guy on Amazon that said the UV isn't legit:
Positive:
- It has a very good suction power and display whether clean or dirty is nice (can't test if it's really good)
- Easy to clean, I know completely different systems
Negative:
- It has NO UV light, only blue/purple. I have UV/UV-C test cards and they don't react to this light at all. My UV-C lamp, on the other hand, proves that the test cards work. Ergo -> NO UV light.
- The cable sits very loosely in the suction cup and falls out easily.
- It heats up, but it's never 60°C, I can easily put my hand under it without it being too hot
Wouldn't buy it again
So not sure what to buy, there isn't much competition in this niche. I already got a Miele C3 Allergy one which is nice but I would like to be able to deep clean my mattress.
-> Moved to Off Topic
With borderline of being status update.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I have one very similar to the one in the link https://www.mi.com/mx/product/mi-vacuum-cleaner-light/
The mattress cleaner is an additional accessory. I've never had another vacuum cleaner, so I don't have anything to compare, but it does suck a lot of dust from the mattress. It does not has uv light and I'm good with that. It also never gets hot.
The UV thing is a good idea I just don't know about the ozone.
