what is the difrence between a rtx 3060 and 3060 ti
GOATWD
 Share
3 minutes ago, Tan3l6 said:
Perhaps GTX 2060?
That also doesn't exist. You mean the 1660?
Mark my answer as solution if it answered your question :). Quote or tag me so I get notified of your reply.
CPU: i5-10400F | GPU: Powercolor RX 6600 Fighter 8GB | SSD: WD Black SN770 1TB, Crucial MX500 500GB | HDD: Seagate Barracuda 2TB | PSU: Corsair RM650x (2018) | Motherboard: ASRock B460M Pro4 | Case: Antec DP301M | Monitor: AOC C24G2U & Samsung SR35 | Headset: Corsair Virtuoso | Keyboard: Drevo Seer Max (Gateron Brown) | Mouse: Logitech G703 | Mousepad: Steelseries QCK Edge XL
5 minutes ago, Tan3l6 said:
The difference is that GTX 3060 does not exist.
Perhaps GTX 2060?
oh i seem to have miss read the cards name sorry
Heh, RTX 2060 - forgot the generation.
... you too 35?
this is a train reck lol
30 minutes ago, GOATWD said:
is there a difrence
GeForce RTX 3060 Family | NVIDIA
Here's the product page showing the stats between the two.
In summary Ti version has less memory and a lower clock speed, but more CUDA cores, which by NVIDIA's testing gives you a 10-25% increase in framerates in select games.
CPU: Ryzen 5 2600  | Motherboard: ASROCK B450 pro4 | RAM: 2x16GB  | GPU: MSI NVIDIA RTX 2060 | Cooler: Noctua NH-U9S | SSD: Samsung 980 Evo 1T
Ti is pretty much definitively superior in every test I've seen.  And the laptop versions of these 2 cards are even further apart in performance.
The 3060 ti is superior hands down.
Your "PC master race" thing is cringe.
ok is this over all in spresifc use caeses
By the way even AMD RX 6600 XT is better than 3060 in most cases.
But yeah - 3060Ti is considerably faster than 3060.
... you too 35?
so 6600xt is that beter then a 1660 super?
By quite a lot:
... you too 35?
By quite a lot:
ok well thx u that card is a lot cheaper so i can get more storge but i have ryzen 5600x what will be the botle neck also 32 gb of ram
In my opinion there would not be practically any bottlenecking in described system.
... you too 35?
ok i was hoping for a botle neck but for 1000 pounds no botle neck is pretey good
 Share
