New Build High Pitched Noise - HELP NEEDED!
Solved by Novica Obadic,
After disconnecting the fans individually, I noticed the noise was being reduced as I unplugged one by one. The problem was in the fan hub of the case itself. I ended up connecting all the fans directly to the motherboard (thank god it had enough connectors for that), and now everything is working quietly and without problem. Thanks to everyone who replied and tried to help. Cheers!
