LF quality electric standing desk
Sweech
Hello,
I've been searching for a month now for an electric standing desk that can hold my set up safely and possibly under $1000.
The current "best" I've found was a custom UPLIFT desk but it priced out at over $1000 and just not ready to invest that much in a desk, preferably.
My set up that it needs to hold,
Samsung Odyssey G9: 50lbs
HX Desk Monitor Arm: 16lbs
~10lbs of miscellaneous items
then the PC itself which I dont know the weight of for sure, please correct me if weight seem off.
Quote
~0lbs - CPU: Intel 13900k
5lbs - Cooler: Arctic 420
~2lbs - Motherboard: ROG Maximus Z790
~1lbs - Ram: G.Skill Trident Z5 (2 x 16GB) 288-Pin DDR5 6600
~3lbs - Storage: SN850X 2tb + older SSD's from last build
5lbs, from this post - Video Card: 4090
30lbs - Case: Phantex 600S
~3lbs - Power Supply: Thermal Take Toughpower GF3 1200w
Total: ~49lbs
If the theory weight of the PC is correct at ~49lbs, then total it will be about 130lbs I would need. But I really want to make sure this is a sturdy and safe desk. With everything its holding, I really don't want anything to happen because of a faulty or cheap desk.
Prefer electronic standing as I do like to stand and too lazy for the manual stand up.
Thank you for any help!
