Need Some Opinions on my Parts List So Far!
Budget (including currency): Preferably below $1600-1700
Country: United States
Games, programs or workloads that it will be used for: Virtual Pinball
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): It will be running 3 monitors: One big, as shown on the list, and 2 smaller ones. It will hopefully run 4k at 144hz or at least close to it.
https://pcbuilder.net/rigs/QCVZcL/
Just looking for some opinions on anything that should/could change. Id prefer not to spend any more money than I have already but if I need to, I will. I am looking to run raytracing so I went with the 3080 but if that is overkill, I will gladly spend less money on a more efficient card. Also the cooler CPU cooler is very big, do yall think it will fit overtop of those ram sticks? Anyways, thank you for looking, and I look forward to speaking with everyone!
Edit: The graphics card I went with is an Asus ROG Strix 3080 OC, however, the site didn’t have it listed so I chose the other one as a placeholder because it had a similar price.
Edited by MyFartSoTart
Weirdly unbalanced.  Monitor the most expensive thing?
Motherboard shouldn't cost more than the CPU.
That PSU is barely enough, I'd go at least 650w for that.
TBD - AMD Ryzen 7 7700x - MSI 6900xt Trio X Gaming - Gigabyte B650 Aorus Pro AX - G. Skill Flare X5 DDR5-6000 32GB - Samsung 980 1TB x4 - Super Flower Leadex V Platinum Pro 850 - ON THE WAY: EK -AIO 360 Basic and ThermalTake Core P3.  Looking forward to building week of Dec 5th.
Emma : i9 9900K 5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200Mhz - 750 EVO 512GB + 2x 860 EVO 1TB (RAID 0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Corsair Virtuoso SE - Logitech G910, G502 - Cooler Master Universal Graphics Card Holder
Plex : Ryzen 5 1600 - Gigabyte B450M-DS3H - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1900 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Samsung 27" + Dell 24"
Raven:  Intel i3 10100F - ASRock H410M-HDV - G. Skill Ripjaws V 16GB 2666Mhz - MSI 1050Ti 4GB - Inland 256GB SSD + Toshiba 2TB HDD - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Spectre 24"
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM, 512GB NVMe SSD, 1050Ti, 4K touchscreen
MSI GF62 - i7 7700HQ, 16GB 2400 MHz RAM, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti
Your list has a 6700XT in it? An overpriced one at that.
I'd maybe look at the 3090 or 3080 Ti, sometimes their pricing is really close to some models of 3080.
You will not be able to use a 500w PSU.
I think it's what he has now...at least that's all I could assume from it.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: Gigabyte GTX 1050 PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
I assumed amazon.com/dp was another country, so figured there was a currency issue.  If not ,then that 6700XT is a bad call.
Other Tech:
Some debatable choices, old CPU, mid range GPU, with 4K screen...That's a $2700 rig really not worth its price !!
Here's an alternative, same price but I think quite better:
PCPartPicker Part List: https://pcpartpicker.com/list/6gkTVw
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($259.99 @ Newegg)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  ($51.64 @ Amazon)
Motherboard: MSI MAG B660 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard  ($189.99 @ Amazon)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($72.98 @ Amazon)
Storage: Western Digital Blue SN570 500 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($42.99 @ Amazon)
Video Card: PowerColor Red Dragon OC Radeon RX 6800 XT 16 GB Video Card  ($612.29 @ Amazon)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($94.99 @ Amazon)
Power Supply: Thermaltake Toughpower GF1 PE 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Monitor: Alienware AW3423DW 34.2" 3440 x 1440 175 Hz Curved Monitor  ($1299.99 @ Amazon)
Total: $2714.85
Generated by PCPartPicker 2022-10-03 17:32 EDT-0400
System : AMD R9 5900X / X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 / RTX3080 Gigabyte EAGLE GPU/ Phanteks P600S case / Customized Watercooling Eisbaer 280mm + Eiswolf2 360mm + VPP755 pump  and 150mm reservoir0.5TB Sabrent Rocket + 2TB WD SN850 NVme Gen4 + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/ 34" 120Hz 3440x1440p Alienware AW3420DW monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse
I’m sorry, I forgot to mention that’s not the graphics card I’m using, instead, I’m using an Asus ROG Strix 3080 OC. I simply chose the other one as a placeholder since the didn’t have the Asus on that site.
Use PC Partpicker then, better.
Total: $2714.85
Are you a Dell salesman?  $1300 for the monitor?!
Other Tech:
Total: $2714.85
I forgot to mention that’s not the GPU I chose but a place holder since the site didn’t have mine listed. I chose an Asus ROG Strix 3080 OC. I will look at the parts you have suggested, thanks!
Oh my gosh, thank you so much! I couldn’t remember the name of the site but the alternate one that I ended up using is garbage. When I get home I will remake my list on pc part picker. Also I forgot to mention it has the prices wrong, that motherboard is only $100. And I had to choose that monitor because it was the best thing I could find for my project dimension & spec-wise.
So a few things:
the website I used is garbage so they didn’t have the GPU I wanted to use, so I just chose the 6700 as a placeholder since it was close to the same price. I actually went with an Asus ROG Strix 3080 OC. Also the pricing of the motherboard is wrong for some, it is actually only $100. Lastly, I don’t know a whole lot about power supplies but the site said that the expected watts needed was 195. I thought that was kinda low as well, so I’m assuming that is just flat-out wrong. Im gonna use pc part picker instead when I get home and hopefully do a bit better.
This build is a little over budget, but it'll give you one of the fastest gaming systems currently available.
You just need to find a case you like, as well as a PSU (something 850w+ is what I'd recommend).
CPU: AMD Ryzen 7 5800X3D 3.4 GHz 8-Core Processor  ($419.99 @ Amazon)
CPU Cooler: Deepcool ASSASSIN III 90.37 CFM CPU Cooler  ($71.98 @ Newegg)
Motherboard: Asus TUF GAMING B550-PRO ATX AM4 Motherboard  ($139.99 @ Amazon)
Memory: Corsair Vengeance RGB Pro SL 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($89.99 @ Corsair)
Storage: Crucial P2 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($75.50 @ Amazon)
Video Card: MSI GAMING X TRIO GeForce RTX 3080 Ti 12 GB Video Card  ($864.99 @ B&H)
Total: $1662.44
Generated by PCPartPicker 2022-10-03 17:44 EDT-0400
Budget (including currency): $1600-1700
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Emulating pinball games at 4k, as close to 144hz as possible, while using raytracing. Also will be used to run two smaller monitors in the proccess.
I just posted this like an hour ago but messed up my list so here is the actual list on pc part picker:
https://pcpartpicker.com/list/gCBPhk
Some people on the last post said there were old components, such as the cpu. Is that going to be a problem in the long run? Lastly, the motherboard is only $100 on amazon, not sure why its listed as $295? Thanks in advance for the help!
Upon further inspection I think this might be a better motherboard for my setup?
https://www.amazon.com/ASUS-ROG-Strix-Gaming-Motherboard/dp/B086QSH67R?dchild=1&keywords=ASUS+ROG+Strix+Z490-E+Gaming&qid=1611913618&sr=8-1&linkCode=sl1&tag=bullseyerevie-20&linkId=e050598eda5bbcf77ef5f10c90129b3d&language=en_US&ref_=as_li_ss_tl
Trying to keep within the asus theme somewhat, since it seems like parts from the same company usually have better compatibility. There are some MSI motherboards that are cheaper though so maybe that would be a better route.
30 minutes ago, MyFartSoTart said:
Here is the updated list on PC Part Picker:
Should be better performance for way less
Motherboard: Gigabyte B660 GAMING X AX DDR4 ATX LGA1700 Motherboard ($139.99 @ B&H)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($44.97 @ Amazon)
Storage: SK Hynix Gold P31 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive ($107.99 @ Amazon)
Video Card: MSI GAMING Z TRIO GeForce RTX 3080 12GB LHR 12 GB Video Card ($759.99 @ Newegg)
Power Supply: Corsair RM750 750 W 80+ Gold Certified Fully Modular ATX Power Supply ($94.99 @ Amazon)
Monitor: Asus ROG Swift PG43UQ 43.0" 3840 x 2160 144 Hz Monitor ($999.00 @ B&H)
Total: $2458.56
Generated by PCPartPicker 2022-10-03 18:37 EDT-0400
Why are you so stuck on using a 10700k? There's much better CPUs out there. Since your CPU and Motherboard in that list are "old new stock" their prices are highly inflated.
Project Hot Box
CPU 12900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU AMD Radeon 6800 XT FE, Case Lian Li O11 Dynamic Mini, Storage Sabrent Rocket Q4 2tbCORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR sf600, Cooling Arctic Liquid Freezer ii 360, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR
Oppbevaring
CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPU Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, MSI 1070 Gaming X 8gb, Case Phanteks Enthoo Evolv X, 2x Storage Samsung 860 Evo 500 GB, 5x Seagate IronWolf 8tb NAS(ZFS1), PSU Corsair RM1000x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans, OS Unraid
Why is the 5800x so hot?
With a great gaming rig you need a great monitor, else it's wasted !
It's expensive, but from all reviews the absolute best one, and worth the $400 it costs over standard IPS hi tier widescreens
Anyway it's a suggestion only
I am definitely changing the CPU, probably to a Core i5-12600KF, after that, I'm not sure which motherboard to go with, but ill look into it.
The reason I have to stick with the chosen monitor is because it fits the dimensions of the pinball cabinet.
The part list is missing a case. It is also uses a 2 generation past CPU. The i5-12400(F) offers roughly the same total performance with much higher performance cores.
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  ($174.99 @ Amazon)
CPU Cooler: ID-COOLING SE-224-XT 76.16 CFM CPU Cooler  ($26.99 @ Amazon)
Motherboard: MSI PRO B660-A DDR4 ATX LGA1700 Motherboard  ($139.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($44.99 @ Amazon)
Storage: Western Digital Black SN770 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($99.20 @ Amazon)
Video Card: MSI VENTUS 3X PLUS OC GeForce RTX 3080 12GB LHR 12 GB Video Card  ($739.99 @ Newegg)
Total: $2415.13
Generated by PCPartPicker 2022-10-03 19:57 EDT-0400
Threads merged. You can edit your original post if you need to make a correction.
 Share
