I Upgrade My GPU and it is showing no signal
Solved by Stormseeker9,
@NerdIsHere did you plug your cable in the GPU itself, not the mobo port?
kacper6768 ·
Posted in Displays1 -
Minuto ·
Posted in Troubleshooting0 -
Williamgame08 ·
Posted in Power Supplies1 -
2
RagePoweredGamer ·
Posted in Troubleshooting16 -
14
Cookiey ·
brau508 ·
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
