GPU fan behaviour (fan tachometer RPM)
tautvydas
 Share
so i bough a card recently and noiticed that when the temps are low the fans dont spin, so no big deali thought.
what i notiiced though that fan tachometer reports that when the load is small and the fan runs at 2+% according to MSI afterburner, it keeps jumping from 0 to 800 to 0 too 930 to 0 to whatver. that is only however under a small load.
if i put some real load like furmark, when gpu gets hotter it seems to stop doing that. the question would be is that expected behaviour or is something not right ?
i'm using GALAX GeForce® RTX 2070 Super EX (1-Click OC), not new so i'm guessing if i got sold a defective one or not
Normal, card has a 0db fan mode so the fan is off under 60C
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
yeah that makes sense, but i'm more concerned that when its under light load ~55 C, my fan tachometers keeps jumping from 0 to 1000 RPM or somehwere in between, does that not harm it ? the % graph is smooth, but the tachometer line is like a mountain view
It will do no harm, you can always set a custom fan curve to stop it from doing that.
|King Of The Lost|
i suppose the fans cant spin at such consistent low rpm to keep the 1-10% fan speed so they need to pulsate, but if it is not damaging i guess thats allright.
tried to run them at come low rpm mode, but it keeps fluctuating anyway, only somewhere around 32-34% they stay on ~940 RPM on constantly, going lower it just flucuiates less often
 Share
