Cheapest DAC with USB input and volume control VIA a remote worth buying?
SuperDerpBro
I've just been using an Apple USB C dongle DAC for my music streaming PC. I'd like to upgrade. I found an FX Audio DAC-SQ3 for CAD $120 (Shipped). Not even sure that would be an upgrade or not. I don't know enough about DACs. Everyone says the lil Apple DAC is quite good. Other than that I see a Topping e30 II but I'm not sure I want to spend that much (over $200 CAD shipped). Anything else I should be looking at?
Cheers 🙂
Cheers 🙂
I would make sure that you understand what a DAC is and the difference between a DAC and amp.  The apple dongle dac is misleading because it's actually a dac/amp I believe, which means it also amplifies.  Typically a DAC does not provide any power to drive headphones, rather it provides a line level signal that needs to be amplified.  Both of the "DAC"s you listed aren't going to power headphones.  I would look at the topping MX3  It's the only budget dac/amp I'm aware of with a remote control.  I bought one many years ago for a friend of mine who is blind and he got years of use out of it before it lost some functionality.  I mention that he is blind because he used it every day all day.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
With what amp are you planning to pair the dac here?
