DF-85 trash it or upgrade fans
Sts610
Hi everyone, my DF-85 is starting to get noisy as the fans are starting to go.  On a tight budget with everything the way it is nowadays.  Looking for suggestions on either cheap but silent fans vs getting a case with enough airflow to cool my 3080.  I can't justify getting another case due to this one doing the job however if its cheaper than replacing 4-7 fans I can live with it.
Thanks!
R5 3600
B450 Tomahawk Max
4 TB SX8100
RTX 3080 12GB
16GB 2X8GB Trident RGB 3600 Cas 18 oc'd to Cas 17
XFX 1250W Pro Black edition
Thanks!
Well any other case you're buying will require the purchase of at least 4 or more fans anyways since the most I've seen bundled are like 3. And those cases wouldn't be cheap either since most would be RGB up the wahzoo.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 17.2.1) | iPhone XR (iOS 17.2.1) | iPad Mini (iOS 9.3.5) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
stock case fans are normally not too good.. but there are exceptions thow mostly you pay extra for them anyway...
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
