NZXT AER2 RGB Fans
Teo182
HI All
Wondering if anyone can help, Just built my a rig and have 6x NZXT AER2 RGB fans however the RGB is not working and they are not showing in cam... they are spinning however..
I believe the control unit can only handle 40 RGB at a time and each fan has 8 so I have dropped a fan however still having no luck. Only have 1 USB header spare on the motherboard so happy to run the 5 fans to use only 1 control unit.
Using the below parts.
Any help massively appreciated !
I'm not all that familiar with the fans, but I suppose they should be about the same as normal ARGB fans, did you daisy chain the ARGB cables and have 1 of them plugged to the ARGB header on the motherboard?
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI MSI PRO B760M-A WIFI DDR4
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
Can’t do that, NZXT, like Corsair, uses a proprietary connection and pinout for its ARGB.  You need to plug them into one of NZXTs controllers.
I used a Smart Device V2 to control 9 AER2 RGBs without issue, just had to split the RGB up between the two channels.
i dont have it plugged in to the ARGB header on the mother board.
I have each individual fan daisy chained to each other with the power going to the control unit which is pluged in to a usb header and a sata.. theres no connection for ARGB the break of cable states USB.
ahh so i cant do it out of the box? need to buy the additional unit ?
I don't know, I don't know exactly what you have the RGB portion of the fans connected to.
Ah good to know, glad that I didn't buy corsair fans. Thanks for the info.
CPU: Intel i5-12400
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
OS: Windows 11 Pro
just googled that device and that is the control unit i have that came with the pack of 3. i dont have the space to connect 2 units so i currently have 3 daisy chained and use the 3 conector to plug them in to 1 channel and the other 2 i have plugged in on there own. still no luck !
