Planning on upgrading to a 4090 with already built system
Kaim
You're "probably fine" if you don't overclock your CPU.
Also make sure to use 3 separate 8-pin PCIe leads from your PSU to the 4090.
I'd probably opt for an undervolt on the 4090 anyway because the rated TGP is beyond insane and unnecessary.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Thanks, I was planning on undervolting anyway because it has worked well with my 3080.
