Has anything technically/physically changed with this kind of monitor power cables over last 10 years?
The connector is standardized, that's why it looks the same. It's IEC C13 and C14 (male and female), see : https://en.wikipedia.org/wiki/IEC_60320#Appliance_couplers
The other most common connectors are C5 (mickey mouse) and C7 ... you see them in lower power things (laptop adapter/charger, small desk lamps etc) .. you can see how they look in the link above.
The contacts inside the connectors are rated for 10A for the C13/C14 connectors, there's a higher current version C19/C20 sometimes used on 1600w+ power supplies that's rated for 16A of current.
The current rating on the cable is just that, how much the cable can safely transfer - has to do with how thick the wires are, the insulation material used on the wires, spacing between wires inside the cable and between the pins in the AC socket, stuff like that. The maximum current is set so that the cable would be safe to use in various environments and not have the wires inside the cable go above some temperature (for example using the cable at 10A may heat the wires inside from 25-30c ambient temperature to around 60c , while the insulation on the wires may be rated for up to 85-100c - so even at 10A, you would still have a big safety margin.
The monitor itself will consume under 100 watts, typically for a 17-19" monitor you're looking at around 40-60 watts. This means the power supply will consume less than 1A of current ( 110v / 60w = ~ 0.5 A) but switching power supplies don't always take power in a smooth continuous flow, like water pouring from a faucet ... some power supplies by design suck a chunk of power in a short burst then for some small amount of time they take almost nothing from the wall socket .... like for example let's say 1.5A-2A of current for 600ms then 0.1A for 400ms, then repeat, averaging out to around 1A of current.
So that's why you would see on the label of the monitor, something like 90v...250v 2A input ... because in 110v countries, the monitor may pull up to 2A in short bursts, but on average the power consumption will be way less.
The power cable is oversized for the needs of the monitor because these cables are mass produced and usually made by other companies - the company making the monitor doesn't make the power cable ... so they don't make a 250v 3A cable because the monitor will peak at 2A maximum, they'll just get the default mass produced 10A cable, and they buy 100k pieces at low price and use the same cable with 10-20 different monitor models.
So to answer your question, yes, the cables are interchangeable, you can use either one on your monitor, and you could probably also use the same cable to power your computer - the same connector is used on power supplies.
