Small Business Networking and Equipment Questions - Wired Internet Alternatives
One idea would be to to rent a house or something across the i-25 highway in Timnath or maybe across that pond/lake/whatever water is to the left of your property, or somewhere with direct line of sight with your property and use point to point wireless to get internet onto your property.
From there, you could use fiber to your office or cat6 if it's less than 100 metes / 300-ish ft.
On your property you could raise a high pole or mount the receiving antenna on top of a thick tall tree, if you have one, and you could then reduce interference, get better signal.
I can't tell the elevation from the picture, if you can get line-of-sight with Timnath or other places.
There's also other solutions like radio modems, but those - and to a lesser degree wireless - will have degraded performance when it rains or snows.
Yeah... found your place on google maps ... looks like the picture is misleading, seems like on the right it's just a costco and parking lot not the actual town. Bottom left corner is more promising, across Strauss Cabin Rd, lots of houses there, maybe you could rent one either as a private person or as office for your company and hopefully that place can get fiber or some solid connection. Then you could just beam internet across the water to your place.
I don't have time to get into details about network equipment and don't have much experience with Meraki, so others can fill in there.
