Build clearance and general advice | SSUPD MESHLICIOUS
Solved by BiotechBen,
https://pt.pcpartpicker.com/list/ZNLjLs
With a case that small, I'd be concerned about keeping a 12700kf AND a 3060ti cool, so I spec'ed a 12600kf. 12700kf still fits in your budget, but at the price difference, it's not a very good value, (€317 vs €470) and the 12600kf keeps your power budget more manageable. So unless you absolutely cannot afford to not have 12 cores vs 10, the 12600kf is a much better value in Portugal.
