Building a Server with a NAS inside a VM and I've realized, I have no idea what NAS OS would be best to go with for this project
29 minutes ago, Captain Taz said:Looking a bit into Unraid run virtually it looks like it's a bit of a pain to set up/has issues that may not be easily fixed or supported vs running it baremetal, and I'd like to run it virtually as I'm more used to functioning and setting servers up in windows.
And totally not also for the sunk-cost of buying 11 pro at this point
I probably should have clarified that expanding on storage probably won't be for another couple years, 12-16 TB should
hopefullybe enough to last me a while. I don't see myself cultivating a movie library to take up tons of space rapidly, the biggest storage items would be my PC backups and game cartridge and disk dumps from my various nintento systems. Would whatever I'd need to do to expand space in Truenas be still that much of a pain?
If your going to virtualize things, why not run unraid bare metal and run windows as a VM under it? Unraid is not difficult to use, and there are SO many videos and resources on how to do it.
ZFS doesn’t let you add drives to a vdev. You would neee to either build a new vdev (which will need its own redundancy), or replace drives one by one until all are a larger size and then you will gain the newly added space.
