Best options after warranty ends?
Solved by Budget DIY,
See? Much more usefull information.聽 And considering your range is fluctuant, I'd recommend asking when you're ~48 hours before buying the thing. Then you still got plenty of time to watch all kinds of reviews, based on the recommendations you might get.
聽
Brand recommendations only gets you so far. For example, Kingston is at least a decent brand. And back when I bought my first SSD, it had some high-end gear for sale. I bought one of those high-end SSD's, and I was REALLY happy about it. Recommended a Kingston SSD to my gf, where other options would have been a nameless brand. Her Kingston SSD was from their budget line... And it br0ke with firmware issues within a year.
