Would I benefit from decreasing my monitor refresh rate?
Solved by Andrewtst,
Depends.
- If your monitor native refresh rate is 165hz and not overclock mode - they is no benefits reduce the refresh rate.
- If 165hz is overclock mode - then yes reduce to next refresh rate (normally will be 144hz) for gain better image quality, for example manage to choose 10-bit than 8-bit color.
Bismarck4117 ·
Posted in Laptops and Pre-Built Systems0 -
CoolJosh3k ·
Posted in Displays1 -
gsgloden456 ·
Posted in PC Gaming1 -
2
1
kacper6768 ·
Posted in Displays2 -
Minuto ·
Posted in Troubleshooting0 -
Williamgame08 ·
Posted in Power Supplies1 -
3
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
