what kind of cooling do i need for a i7 12700 non-k
Solved by danomicar,
yeah i think that the 240mm will be more than enough. 360MM is definitely overkill unless you are planning on having this thing loaded 24/7.
My corsair 240mm h100i came with thermal compound pre-applied and works really well keeping my 5800x3d below 60c even under heavy loads.
lightfire ·
Posted in Hobby Electronics0 -
1
Trissssss ·
Posted in Laptops and Pre-Built Systems2 -
Mortal_2077 ·
Posted in CPUs, Motherboards, and Memory2 -
Hellowpplz ·
Posted in New Builds and Planning2 -
2
2
3
3
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
