Specifically for gaming, how much does a CPU really matter?
Go to solution Solved by Eigenvektor,
The CPU needs to be fast enough to run the game's code and keep the GPU fed with data (draw calls) to work on. The faster your GPU, the faster your CPU generally needs to be. Also depends on the game, some contain more game logic that requires a faster CPU. Aside from that, a fast CPU is usable for more than just gaming, some people use it for video encoding or other stuff.
I was looking at some benchmarks of all AM4 CPU generations at 1440p, even 4 vs 8+ cores.
Quite honestly... IMO the difference is not worth so much, even when comparing Ryzen's 1st gen vs 5000 series the difference is minimal.
The biggest change pretty much comes down to upgrading the GPU (or so it seems)
So why does it matter having the best CPU?
It doesn't. You just need a CPU that's enough to feed your GPU in the games you play, at your chosen res/refresh and settings. Most people don't have the best CPU, yet most people do just fine.
Main PC (tearing this down in a bit, 7980XE coming soon™)- i7 6950X - EVGA X99 Classified - 4x8GB 3200Mhz CL16 DDR4 - 2060 Super FE - 1TB 970 Evo/1TB MX500 - LG WH14NS40 BluRay Drive - EVGA 1000W G3 - Corsair Air 540 - Noctua iPPC NF-A14 3000 (rear) + 3x Noctua NF-P12 redux-1700 PWM (radiator) - LG 27UK650-W (27" 4K60hz) - Custom CPU/GPU Loop w/single 360mm rad - Windows 10
Project Rig (WIP) - Xeon I forgot the name of - NH-L12S - EVGA X99 Micro 2 - 4x4GB 2800MHz DDR4 - WX2100 2GB - 256GB 960 Evo - no PSU, currently in a Node 804
Daily Devices: 2015 15" MacBook Pro (Work Laptop) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: Mac Pro 1,1 (2x dual cores as I haven't swapped the quads in yet, 32GB DDR2 and a 512MB HD4870) running El Cap/Lion/sometimes other Mac OS X versions - iPod Video (5th gen)
I am not allowed to have my PC specs in my signature.
It depends on what frame rates you want. If you're going 240hz then you need a fast CPU. If you're going for 144hz you don't really need anything over a 5600x. If you go too low end you'll get frame inconsistency which you can definitely feel and won't show in benchmarks that are only looking at average FPS.
it matters alot when u hit the "wall" on a cpu, if you don't it's just gonna be pumping out a bit less frames
zen 1 to zen 3 is about a double for games that are cpu intensive, so let say u buy a 4090 for 2000usd, 50% of that goes to waste with a zen 1. a 5800x3d +motherboard is about 500usd, making it an efficient buy with a 4090.
Generally for a new build atm, i'd go with ddr5 or a 5800x3d minimum with existing ddr4 ram.
I'm pushing the limits of my 9900k atm, it will slow a 4090 down by 30-40%, the 5950x will hold it back too, so i wont be getting a gpu ungrade til i do a ddr5 build.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Yes, its the CPUs job to deliver the frames that the GPU has to draw out, so the higher the FPS the harder it is on the CPU. This is why you can see bigger difference between CPUs on low resolution. At higher resolution like 1440p and 4K the load is shifted more to the GPU.
In addition to the frames its also the CPUs job to do physics simulation and tracking objects, so if there are a big open world with a lot of movement, explosions and things falling its harder for the CPU than in more closed off linear games.
So the CPU utilization depends a lot on the type of game you are playing
If you want me to answer, please use the quote function or tag me. I dont get notified unless you do
Keep in mind it is not a linear relationship between CPU performance and fps. Too weak a CPU will hurt gaming performance. Once you get to "good enough", going much higher makes much less difference. Today I'd say "good enough" could be hit with a 6 core Zen 2 or Coffee Lake CPU, or newer. 4 cores work for sure, as do older generations, but you will encounter more limitations. 8 cores can offer a smoother experience, but once you're into 12, 16 or more cores, it doesn't really matter.
TV Gaming system: Asus B560M-A, i7-11700k, Scythe Fuma 2, Corsair Vengeance Pro RGB 3200@2133 4x16GB, Gigabyte 2070, EVGA Supernova G2L 850W, InWin 303, Samsung 980 Pro 2TB, LG OLED55B9PLA 4k120 G-Sync Compatible some old 32" 768p TV
Streaming system: Asus X299 TUF mark 2, i9-7920X, Noctua D15, Corsair Vengeance LPX RGB 3000 8x8GB, MSI 3070 Gaming Trio X, Corsair HX1000i, GameMax Abyss, Samsung 960 Evo 500GB, Crucial BX500 1TB, Acer Predator 24" 1440p1444 G-Sync + LG UW 1440p60
Gaming laptop: Lenovo Legion, 5800H, DDR4 3200C22 2x8GB, RTX 3070, SK Hynix 512 GB + Crucial P1 TB SSD, 165 Hz IPS 1080p G-Sync Compatible
 Share
