Side panel too tight on the PCI-E cables?
Fatty
Hello, I currently have a 6800xt inside this case, deepCool Matrex 50 mesh.
The case dimensions are: 442X210X479mm
Here is a pic ( it's hard to show because the side panel is reflective ofcourse)
https://i.imgur.com/PCFkrxi.png
Is the side panel dangerously tight on the cables?
the psu is EVGA supernova 750 GT
Looks fine from what I see.
I'd say it's not a problem unless you have to use force to get the side panel to close, which doesn't seem to be the case.
Ryzen 5 5600X - MSI B550 Mag Tomahawk - Corsair Vengeance RGB Pro SL 3200 (4x8) - EVGA RTX2060 XC Gaming 12gig - Crucial P2 250gb nvme ssd (OS) - WD Blue 1tb sata hdd (general storage) - Seagate Barracuda 4tb sata hdd (games) - iBuypower Element Reflect
I do actually need to do that, that's why I was worried, I searched for other more expensive cases and they are all 20-21cm wide as well, I don't really want to pay x2 the price just for a slightly bigger case
Nah, it should just plunk down when you get it on there, if you have to push against it then there's a tolerance issue.
But as I said, it looks fine, the cables don't look kinked or anything.
As long as the cables do not get pinched, at least not hard enough to cause deformation on the cable, it will be fine.
Not an expert, just bored at work. Please quote me or mention me if you would like me to see your reply. **may edit my posts a few times after posting**
CPU: Intel i5-12400
GPU: Asus TUF RX 6800 XT OC
Mobo: Asus Prime B660M-A D4 WIFI MSI PRO B760M-A WIFI DDR4
RAM: Team Delta TUF Alliance 2x8GB DDR4 3200MHz CL16
SSD: Team MP33 1TB
PSU: MSI MPG A850GF
Case: Phanteks Eclipse P360A
Cooler: ID-Cooling SE-234 ARGB
OS: Windows 11 Pro
Pcpartpicker: https://pcpartpicker.com/list/wnxDfv
Displays: Samsung Odyssey G5 S32AG50 32" 1440p 165hz | AOC 27G2E 27" 1080p 144hz
Laptop: ROG Strix Scar III G531GU Intel i5-9300H GTX 1660Ti Mobile| OS: Windows 10 Home
