Is a 480MM rad enough for my next upgrade?
I wish to upgrade my computer's water cooling loop by having my 3090 founders water cooled and have my room not turn into a furnace or at least a nice cosmetic water-cooled GPU. I'm unsure if my CPU will get hot because of my GPU and/or be enough cooling for them both.
my spec's
CPU: I7 12700k won't overclock unless its becoming old
GPU: 3090 Founders
RAM: 2X16GB's 5200mhz
Power Supply: 1200 Watt platinum
Pump: Pacific PR22-D5 Plus
CPU block: Hydro X series XC5 RGB PRO
Your room will still be equally hot. The heat generated wont change in any way. If a card generates 300w of heat it will generate 300w of heat no matter what type of cooling is used.
Your cpu will be hotter but this combo has been done multiple times before on a 360 rad and it's fine.
You really don't need that much cooling for a non overclocked 12700k, even a 280mm rad will do
For the GPU a 360mm will be ok as well
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Dont need much for a 3090. Mine tends to sit at 39-42c. Im sure it could be more in a hot house. Ran two 280's but added a third back into the loop again.
It will be fine as it, but your not knowing your ideal temps, I couldnt say.
Being me, if my case was that large, I'd have more.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
before u grab another 480 rad
if yer mobo has a 2pin temp sensor header or if you have a corsair commander unit
i would grab a temp sensor fitting
that way you'll know your delta between coolant & ambient air
personally i'm using the temp sensor fitting from my corsair xd5 (already swap pump housing) with my aquacomputer quadro
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
Aquasuite is simply the best and I chucked that piece of crap Corsair Commander Pro in the parts bin. I never got it to not conflict with HWInfo64 even with the proper setting changes, etc.
I just installed a Highflow Next in the loop to go with my Octo and being able to set fan curves based on coolant temp is a game changer.
Zen 3 Daily Rig (2022 - Present): AMD Ryzen 9 5900X + Optimus Foundations AM4 | Nvidia RTX 3080 Ti FE + Alphacool Eisblock 3080 FE | G.Skill Trident Z Neo 32GB DDR4-3600 (@3733 c14) | ASUS Crosshair VIII Dark Hero | 2x Samsung 970 Evo Plus 2TB | Crucial MX500 1TB | Corsair RM1000x | Lian Li O11 Dynamic | LG 48" C1 | EK Quantum Kinetic TBE 200 w/ D5 | HWLabs GTX360 and GTS360 | Bitspower True Brass 14mm | Corsair 14mm White PMMA | ModMyMods Mod Water Clear | 9x BeQuiet Silent Wings 3 120mm PWM High Speed | Aquacomputer Highflow NEXT | Aquacomputer Octo
Test Bench:
CPUs: Intel Core 2 Duo E8400, Core i5-2400, Core i7-4790K, Core i9-10900K, Core i3-13100, Core i9-13900KS
Motherboards: ASUS Z97-Deluxe, EVGA Z490 Dark, EVGA Z790 Dark Kingpin
GPUs: GTX 275 (RIP), 2x GTX 560, GTX 570, 2x GTX 650 Ti Boost, GTX 980, Titan X (Maxwell), x2 HD 6850
Bench: Cooler Master Masterframe 700 (bench mode)
Cooling: Heatkiller IV Pro Pure Copper | Koolance GPU-210 | HWLabs L-Series 360 | XSPC EX360 | Aquacomputer D5 | Bitspower Water Tank Z-Multi 250 | Monsoon Free Center Compressions | Mayhems UltraClear | 9x Arctic P12 120mm PWM PST
