Blurry motion using Kodi with a 4K Sony A80J
Solved by DJZ,
4 hours ago, Blue4130 said:Plex, vlc, windows media player, pretty near all players will be able to play from smb shares.
Thanks! I've gone ahead and tried Plex and for some reason, the result is the same... Not sure what's going on
SOLVED: It was a problem with the TV settings. Sony's "Motionflow" was making everything bad and I didn't realize I had to change the settings for each input mode.
