What power supply is good for 3080 + I7-12700k
Those calculators exist to sell power supplies, and worse they try and advertise very specific power supplies.
The 12700k at stock draws under 200 watts in real load. With an OC you’re looking at 240-250 watts at the most.
Depending on the specific 3080, it can be up to 380 watts. Though the vast majority will use around 320-340 watts.
So total worst case peak synthetic load, like you have one of the obscenely high end 3080’s and a heavily overclocked 12700k, you’re looking at 630 watts for the two core components. Write the rest up as around 150 watts, drives, fans, maybe an aio, motherboard, ram, etc.
780 watts, under an absolute worst case scenario where every single part of your system is absolutely tapped out, you’d still be fine with like a Corsair RM850x
Im running an i9 11900k at 5ghz with a 3070ti on an rm850x without issue.
