Please help, I need 2000 (monochrome and simple) images printed, split across 125 pages, 16 images per page. What is the quickest way to do this?
EDIT: I didn't connect the 'Wallet' remark with my Contact Page suggestion initially... Since realizing that, I wonder if some of the parameters involved in that method might be altered to accomplish what you need, and I think I found a way to do it. I've increased the font size to help you find the text amongst the screenshots.
Just as you would for the other straightforward Windows batch image print options....
First, group all your images in one folder.
Select all the images desired to print.
Select the options shown in screenshot one, or whatever puts them in 2x2 (4 to a page) in landscape orientation.
Select Print To PDF, give it a file name, and let it do its thing.
Next, click on the PDF, which will usually load in your browser. I use Firefox. Printing a PDF from Firefox (and I imagine most other methods) will give you the option to print two pages per sheet with no margins in Portrait orientation, as shown below. It might leave some gaps between images, but I think that's the best quick and dirty you're going to get.
