Can I take a top mounted AIO PC and lay it on its side?
By
soloredis420
in Cooling
in Cooling
Solved by KingTdiGGiTTy,
It is relatively difficult to damage AIOs
it really doesn't matter what orientation you put them in, there's a "best practice" but it's nearly negligible.
so unless you lay your PC on it's side with a hammer, everything should be fine.
thstudios ·
Posted in Storage Devices0 -
skkler ·
Posted in Cases and Mods3 -
Iggzy ·
Posted in Troubleshooting3 -
3
11
Gat Pelsinger ·
Posted in Linux, macOS and Everything Not-Windows10 -
7
lightfire ·
Posted in Hobby Electronics1 -
7
6
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
