How do i stop my headphones from hurting the top of my head?
Solved by jaslion,
It has quite the clamp fit and doesn't have a lot of padding.
Sometimes headphones simply aren't compatible with you head.
A stupid but effective solution is wrapping a cleaning cloth or small towel around the top.
4
Inception9269 ·
Posted in PC Gaming0 -
Chimneyfan52 ·
Posted in Troubleshooting4 -
2
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
