1070ti core clocks stuck at ~1151 MHz
39 minutes ago, KingTdiGGiTTy said:A good ol' DDU should fix it
Damn, well it seems like it still doesnt want to work..
After i uninstalled the drivers it hopped up to ~1650MHz for a sec so i thought it was working again, however after i installed the new Nvidia drivers its once again stuck at ~1164MHz?
Seems like Afterburner doesnt like my GPU anymore..
EDIT: i accidently closed afterburner completely when i tried to start a game and the clocks all jumped back to normal! However i opened afterburner again they all dropped down to ~1164MHz. Seems like afterburner is my enemy here. I never really had a major overclock on my card to begin with so i think ill just unistall it and run the card at stock speeds.
EDIT 2: well i found a bit more info. Seems like my saved preset(1) in afterburner somehow was fucked. Reverting to stock settings, applying the overclock and then saving it to a new preset(2) fixed the issue, now the card boosts as it should.
