PC keeps randomly turning off monitors and then turning fan speeds to max.
Solved by SandmanSoggs,
@emosun @GuiltySpark_Thanks for the help. It looks like the cable which gives the GPU power from the PSU wasn't working properly. I tried removing the power cable whilst the PC was running and it did the exact same thing. I've moved the PSU to GPU cable round to a different one and now it works fine like it did before.
