Corsair 4000D Airflow Fan Config?
Does anyone know an optimal fan configuration for the 4000D Airflow?
I'm planning on using a NZXT Kraken x63 280mm AIO and putting it at the top, but there is also room for a 360mm version put at the front.
There are also 2 included 120mm case fans.
if you don't have low profile ram, the 280mm rad fans probably won't clear the ram. i have my 4000d setup with 280mm rad front(intake), and top 2x140mm fans(exhaust) and the rear 120mm(exhaust). might be a better way to configure it, but works well on my build
 Share
