Help picking out case fans for new build
Ashino
Hello, I'm about to get a new build and I need help picking 3+ good fans with high CFM and a reasonable price to go into this case
https://www.amazon.com/gp/product/B08M4BN431/ref=ox_sc_act_title_8?smid=ATVPDKIKX0DER&th=1    Corsair Icue 5000x. I would prefer that the fans are 120mm and white, but that's not really necessary as long as they're good PWM fans that fit in the case. Thanks in advance.
Doesn't that case come with 3 fans already? That's more than enough most of the time.
The Arcic P12 ($10 a piece, $30 total) should be more than enough. Or if you want RGB or don't have a fan controller yet (most boards don't support 6 fans without one), the Lian Li ST120 ARGB 3 pack ($48 total) should do and comes with a controller.
Noctua or Be Quiet have great fans, but not in white. You can get either in black though, which IMO looks good against White.
