GPU not achieving power limit
Solved by DoctorNick,
6 minutes ago, tikker said:1080p should be breakfast for a 3080 Ti. I would fire up GPU-Z alongside the benchmark and see what it reports as the limiting factor in the PerfCap Reason box. It could, for example, also be hitting a voltage limit, limiting the amount of power it can draw.
Also Palit lists 350 W for the GameRock, not 400: https://www.palit.com/palit/vgapro.php?id=4143&lang=en&pn=NED308T019KB-1020G&tab=sp
You are correct good sir. The OC version of the card is 400W though. Just another bios. You can get the OC bios here: https://www.techpowerup.com/vgabios/234545/palit-rtx3080ti-12288-210405-1 @Bobbysixjp
