Monitor Troubles
Weezy
Hey everyone
I just purchased two new monitors, which I will use as an extension from my laptop for work, and then use both for my non-work stuff for my personal desktop. As you can see in the picture, I can't seem to get the image to line up from one monitor to the other through my work laptop. I tried DP first, resolution is the same for both monitors, etc.. then I tried HDMI, same result.
Here's the rub, for DP, I am running them both through a Dell docking station - it has 2 DP ports and 1 HDMI port. Then I tried running 1 HDMI from the docking station and 1 HDMI from the laptop itself. Am I missing something? Any help is appreciated
Intel Core i7-11700K || Nvidia GeForce RTX 3060 Ti || 1TB Corsair MP600 PRO XT & 2TB Samsung 980 Pro || Adata DDR4 3200 4x8GB || Asrock Z590-C/ac
did you try messing around with the monitor positions in windows display settings? you can move the monitors up and down to get them aligned how you want them.
