Should I swap my AIO?
Solved by jaslion,
2 hours ago, x Princess Leliana x said:Pump header goes into AIO Pump header on mobo, fans go into a seperate header that I then just plug into a regular fan slot on the mobo?
Yup.
Oh the ak 620 wins by far here for price. As for performance the ak620 will be a bit better and will do better at lower noise levels. The deepcool fans are louder since these are the cheaper ones made for their aio's.
Either way between that deepcool you like or a a620 you cannot go wrong for the cpu you have. The ak620 will be better out of the box and quieter. The deepcool will be louder and a bit worse but have the rgb bling you seem to want.
