Does A MSI GTX 1050Ti Or A GTX 1650 Work With A 300w PSU?
TRBES
Does A MSI GTX 1050Ti Or A GTX 1650 Work With A 300w PSU , I Really Need To Know
What psu? Can you give us the model? 300w is not enough info.
With a goos quality unit its possible IF it isnt beinf pushed to the limits AND has the needed connectors. There is also some no additional power gtx1650s which can also work. IF its a good quality unit
idk it my pc is from a ACER ASPIRE Tc-280 so idk the psu
Yeah probably.  OEM PSUs are usually extremely accurate with the ratings on the side, as they are meant for the OEM to use as an exact metric as opposed to being a marketing device.  What you're used to getting from a bottom-tier 500w you'd get from a 240w OEM PSU.
I edit the shit out of my posts.  Refresh before you respond.
so i can put a gtx 1650 in my pc? with a 300w psu or even a gtx 1060?
I Might Make Upgrades To My PC So Does A GTX 1050 Ti Work With A 300W OEM PSU?
should be fine but dont expect to upgrade up to anything else
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
GTX1050Ti is an up to 75 watt part, it can get all it needs from the PCI slot.
Some 1050Ti models come with an extra power socket normally because they have an over built cooling system, so the fan/ fans need more power than the card can pull from the PCI slot.
as long as you dont get a model with a 6 pin unless your psu comes with one?..  i have a HP pavilion with a am4 board, so a more modern one. ive installed a 310 psu which has a 6 + 2 pin.  havent tested a gpu yet,  but if yours has that cable then you should be able to go over the 75w limit,  but i would say dont go over the 100w as i suspect your psu would be designed differently than mine(these HP ones are 12v only).  best to find one and google it and look up techpowerup for details.
