rtx3080 Rtx 3080 Idle temperature 55C
Solved by Karoliokompai,
6 hours ago, Zando_ said:From the review I'm lookin at, the Ventus runs a bit hotter than the Founder's Edition 3080, so that load temp would be expected. The idle being in the 50s is likely due to a low/0rpm fan mode that most new cards have.
Review btw:
Thanks for letting me know! I was about to case swap my PC ;D
