PCIE Dust Cover, anyone using them?
Solved by Dedayog,
33 minutes ago, Poinkachu said:Uh, the cover inserts into the slot i think.
https://www.modcover.com/products/PCIE-16X-Silicone-Rubber-Dust-Cover.html
Yeah, those are safe like they said. I may get some too then, thanks!
Fluuwu ·
Posted in CPUs, Motherboards, and Memory1 -
2
damian61 ·
Posted in Troubleshooting0 -
kofman13 ·
Posted in Linux, macOS and Everything Not-Windows2 -
Gabefair ·
Posted in General Discussion3 -
Jeeperforlife ·
Posted in New Builds and Planning6
play_circle_filled
Latest From ShortCircuit:
If you can only get one computer, get this one. - ASUS ROG G14 (2024)
