Budget (including currency): €6000 -> €7000
Country: Netherlands (I am planning to shop at Alternate.nl)
Games, programs or workloads that it will be used for: GPU Rendering, GPU/CPU base simulation, VFX work, UE5 Development
Software that I use often: Maya, Houdini, I render with Redshift (GPU renderer)
I need a lot of headroom on things like caching stuff in RAM.
Hello! It's been quite a while. I built my last PC over 4-5 years ago and especially now that I am putting it through it's paces, It's starting to show it's age.
I want to build an entirely new system.
Here's the parts I know for SURE are gonna be in there:
Case : Lian Li O11 (wide case, can hold lots of things)
CPU: AMD Ryzen 9 5950X
GPU: GTX 3090 TI (I don't know which brand to go with yet)
I just need info for:
A motherboard: I was thinking of the GIGABYTE X570S UD.
2 TB NVME Drive for software + OS (Seagate FireCuda 530 2 TB SSD is what I had in mind)
8 TB HDD for long term storage. (Seagate SkyHawk 8TB)
64 Gb Ram, preferably > 3000 Mhz (I need help with matching RAM to my motherboard, last build I did I screwed up there)
A proper power supply. How much power is this going to draw?
Cooling: I want to invest in some quality fans and heatfins to cool my CPU with.
I hope I provided you guys with enough info!
I really appreciate the help since I'm very insecure about the RAM, power and cooling part.
Some overhead in power wouldn't hurt since I am running 2 graphics cards, after all.
Thanks,
Sasbom
UPDATE:
I went with a DARK ROCK PRO4
I upgraded mobo to GIGABYTE X570 AORUS XTREME.
I was only able to get 1 GPU, instead of the 2 I'd hoped for, but it's the MSI GeForce Suprim 3090 ti.
I've got 1500W power, so hopefully I can fit in a second GPU in the future.
For RAM I went with the CORSAIR Vengeance LPX 64GB (4x16) , it was listed as being compatible. https://pangoly.com/en/compatibility
I added 5 Noctua NF-A12x25 PWM fans because my PC is gonna be running LONG. :')
That kinda solves a lot of my issues and ensures I won't be bottlenecked in the future!
