Corner desk help. Need suggestions...
Dedayog
 Share
So I am moving, cohabitating with my SO.  My office will be relegated to the 4th bedroom.  There is a spare bed and a dresser, which leaves me with a corner and/or back wall.  I have 5 feet from the wall east wall to the bed, so any desk would either need to be a corner desk or a 4-5 foot wide regular desk.
It need to fit a 34" UW and 5" Mackie CR5BT's across it.  I'm looking at some sit/stand desks, but wondering if a corner desk would be better and allow more room for the monitor/speakers, without pushing my chair back into the bed.
Not as concerned about price as I am in getting a decent desk that fits my needs.  I guess I'd say up to $500 USD for starters.  Any thoughts or suggestions would be appreciated.
Emma : i9 9900K 5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200Mhz - 750 EVO 512GB + 2x 860 EVO 1TB (RAID 0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - AOC AGON 35" 3440x1440 100Hz - Mackie CR5BT - Corsair Virtuoso SE - Logitech G910, G502 - Cooler Master Universal Graphics Card Holder
Plex : Ryzen 5 1600 - Gigabyte B450M-DS3H - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - 840 EVO 256GB + Toshiba P300 3TB - TP-Link AC1900 PCIe Wifi - Cooler Master MasterWatt Lite 500 - Antec Nine Hundred - Samsung 27" + Dell 24"
Raven:  Intel i3 10100F - ASRock H410M-HDV - G. Skill Ripjaws V 16GB 2666Mhz - MSI 1050Ti 4GB - Inland 256GB SSD + Toshiba 2TB HDD - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Spectre 24"
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Lenovo 720S Touch 15.6" - i7 7700HQ, 16GB RAM, 512GB NVMe SSD, 1050Ti, 4K touchscreen
MSI GF62 - i7 7700HQ, 16GB 2400 MHz RAM, 256GB NVMe SSD + 1TB 7200rpm HDD, 1050Ti
As someone with a 5ft desk, it's really not as wide as you might think. I'd stick with a regular desk instead of an L desk otherwise it'd likely feel cramped
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 1800X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 32GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
Go to an ikea and choose two table tops and some legs/cabinets and you're good to go. you can easily spend less than $500 on that.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    MSI Optix MAG342CQR 34" UWQHD
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
  • 3 weeks later...
You'll be fine with a 48" wide desk.
http://displaywars.com/40-inch-16x9-vs-34-inch-21x9
I have a 40" 16:9 which is functionally wider than your 34" UW (technically even wider than a 34" SUW).  I have just enough room at the corners of the desk to put my speakers.  So add in a couple extra inches for a smaller monitor--and you'll be fine with a 48".
I'd probably put my tower on an end table between the desk and the bed--just so you only have the KB/M and speakers/monitor on the actual desk surface.  > 48" desks are only necessary if you insist on having the tower on the desk itself, have multiple KB's (eg. laptop) that you need access to, or have a display that is so massive that it requires additional horizontal space.
 Share
