120hz 10bit no freesync vs 165hz 8bit freesync premium.
Solved by Dukesilver27-,
Update:
Just in case someone looking for the same solution and found this thread.
Found a way, firstly set the refresh rate to maximum on the monitor's OSD, turn on Freesync, and then instead of setting the maximum refresh rate on the monitor OSD to 120hz, set it in the Advanced Display setting on windows. That way the color would still be 10 bit but VRR/Freesync is still enabled.
Marked as solution to pin this post to the top.
