Xeons for dual workstation (Thinkstation D30)
Hi folks
My long suffering Dell Precision T7600 had died on me, the mainboard had developed a fault where only three memory channels worked and now has died altogether.
So I have 16x 8Gb DDR3-12800R and a pair of E5-2667s plus various drives and expansion cards salvaged to build a replacement machine.
I've bought a dirt cheap (70ukp) Thinkstation D30 and because I got is so cheap, I have been thinking I can afford to buy a pair of v2 Xeons as an upgrade - the E5-2667s have a passmark rating of 7725, single thread rating is 1678 and the two CPUs together rates at 12798.
Obviously, some of the high end E5-269x v2 chips would be the best upgrade but they are still quite expensive, over 100ukp each.
So I have been looking at cheaper options and the E5-2680 v2 seems a good bet as it's available for 25ukp each and the passmark ratings are good - 12631, 1794 single thread and 20691 for a pair, which would be a significant upgrade over the E5-2667s.
Another option is the E5-4650 v2 which is even cheaper, they can be had fr around 20ukp each and have 10 cores, but I can find no benchmarks.
Anyone got any experience of this chip? Also, does anyone know if there might be any compatibility issues with using a 46XX v2 series chip in the Thinkstation D30?
How expensive is a used 3900x? That things beats dual e5 2680v2s and has a much much much higher single core performance.
The d30 doesn support e46 series cpus
Er, why are you suggesting I buy a Ryzen that won't fit in my machine and won't work with the memory I have?
Sensible suggestions only please.
It is a sensible suggestion. You're talking about "upgrading" 10 year old CPUs, when a single current consumer chip will beat them in every way possible. Technology becomes obsolete eventually, sorry to say.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Mellanox ConnectX-3 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi (all-around awesome machine)
Proxmox Server (Veda): Ryzen 7 3800XT | AsRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4x 10TB WD Whites / 4x 14TB Seagate Exos / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X540-T2 10G NIC | LSI 9207-8i HBA | Fractal Design Node 804 Case (side panels swapped to show off drives) | VMs: TrueNAS Scale; Ubuntu Server (PiHole/PiVPN/NGINX?); Windows 10 Pro; Ubuntu Server (Apache/MySQL)
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / Seagate 1.5TB HDD | Corsair CX450M | Viewcast Osprey 260e Video Capture | Mellanox ConnectX-2 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Camera: Sony ɑ7II w/ Meike Grip | Sony SEL24240 | Samyang 35mm ƒ/2.8 | Sony SEL50F18F | Sony SEL2870 (kit lens) | PNY Elite Perfomance 512GB SDXC card
Network:
                           ┌─────────────── Office/Rack ────────────────────────────────────────────────────────────────────────────┐
Google Fiber Webpass ────── UniFi Security Gateway ─── UniFi Switch 8-60W ─┬─ UniFi Switch Flex XG ═╦═ Veda (Proxmox Virtual Switch)
(500Mbps↑/500Mbps↓)                             UniFi CloudKey Gen2 (PoE) ─┴─ Veda (IPMI)           ╠═ Veda-NAS (HW Passthrough NIC)
╔═══════════════════════════════════════════════════════════════════════════════════════════════════╩═ Narrative (Asus USB 2.5G NIC)
║ ┌────── Closet ──────┐   ┌─────────────── Bedroom ──────────────────────────────────────────────────────┐
╚═ UniFi Switch Flex XG ═╤═ UniFi Switch Flex XG ═╦═ Byarlant
   (PoE)                 │                        ╠═ Narrative (Cable Matters USB-PD 2.5G Ethernet Dongle)
                         │                        ╚═ Jesta Cannon*
                         │ ┌─────────────── Media Center ──────────────────────────────────┐
Notes:                   └─ UniFi Switch 8 ─────────┬─ UniFi Access Point nanoHD (PoE)
═══ is Multi-Gigabit                                ├─ Sony Playstation 4
─── is Gigabit                                      ├─ Pioneer VSX-S520
* = cable passed to Bedroom from Media Center       ├─ Sony XR65A80K (Google TV)
** = cable passed from Media Center to Bedroom      └─ Work Laptop** (Startech USB-PD Dock)
Retired/Other:
Laptop (Rozen-Zulu): Sony VAIO VPCF13WFX | Core i7-740QM | 8GB Patriot DDR3 | GT 425M | Samsung 850EVO 250GB SSD | Blu-ray Drive | Intel 7260 Wifi (lived a good life, retired with honor)
Testbed/Old Desktop (Kshatriya): Xeon X5470 @ 4.0GHz | ZALMAN CNPS9500 | Gigabyte EP45-UD3L | 8GB Nanya DDR2 400MHz | XFX HD6870 DD | OCZ Vertex 3 Max-IOPS 120GB | Corsair CX430M | HooToo USB 3.0 PCIe Card | Osprey 230 Video Capture | NZXT H230 Case
TrueNAS Server (La Vie en Rose): Xeon E3-1241v3 | Supermicro X10SLL-F | Corsair H60 | 32GB Micron DDR3L ECC 1600MHz | 1x Kingston 16GB SSD / Crucial MX500 500GB
It is not a sensible suggestion as it completely ignores the context of the the question, which is my very small budget and wish to use the 128Gb of RAM and other components that I already have.
Dual E5-2680 v2s are a good bang-for-the-buck option in your price range, if your workload can take advantage of all those cores. If it can't, you probably won't see a massive difference, and dual E5-2667 v2s would make more sense due to their higher clock speeds (and single-core performance).
If the E5-2667s you already have were adequate though, I'd recommend keeping them and saving the money so you can upgrade to a newer platform in the not-too-distant future.
Yeah, I originally chose the E5-2667s for their higher lcock speed, although for the tasks this machine will be put to, a lot of RAM and storage is more important than sheer CPU power. I also have a Dell T7810 with a E5-2873v3 which is my Windows daily driver machine, this dual setup will run Linux and spend it's time chugging away doing a lot of image processing of photographs and videos.
I'll upgrade when the price of DDR4 ECC drops nice and low, which will happen when the data centres and server farms upgrade from it. They will probably bump a load of newer Xeons onto the secondhand market too, we shall see.
I made a little chart to help me see the options in perspective. It's largely a case of what CPUs can be found at what price.
Actually, I have found out that it does, as does the S30.
So, please, if you don't actually know something, then please don't chime in with incorrect information.
Where did you find this?
Officially the d30 doesn't support it as per lenovo's specsheet that I found and online the consensus was that it was a nogo apart from a couple lower end core count ones being the e5 4610 and e5 4620 which are often supported on unsupported machines (since they are basically just e5 2650's but made to be in a 4x config) basically by accident. Neither are cpu's youd want as they tend to be more expensive than their better performing cousins like a e5 2650 v1 or v2.
May wanna have a look at the e5 2695's too as they are 12 cores and are often overshadowd by the e5 2697v2 making them a lot cheaper for almost no perf difference. Saw a couple for about 40-60 pounds on ebay doing a quick search. Beasty lil things for not a lot of money.
Other than that get the cheapest base 3ghz or better v2 8 core cpus you can get.
Please, you clearly don't know what you're talking about, so kindly stop, it is not at all helpful, just obfuscating.
I contacted Lenovo, they told me that all the 46xx v2 chips work, I also spoke to a person running a pair of 4658L v2s in a D30 and another person running a 4650 v2 in an S30
I do know some but can always learn more.
The s30 supporting e5 46 chips is documented but I could almost find nothing from the d30 and found a mixed bag of results thus opting for my response. I know of the e4610 and 4620 normally being surefire supported cpu's even if they are off the list but the rest is pretty much up to whatever is and isnt bios locked.
It's good that the e5 46 series is available but as far as I can see the regular e5 26 series seems to be the better value for money in terms of performance and single core performance. Also helped by more cache.
So I'd opt for the higher clocked 8 cores or see if a pair  of 2690v2 or 2695v2 can be found for cheap. Another good value one is the e5 2670 v2 which is often overlooked.
