Strange buzz followed by a clicking noise coming from psu - Corsair RM750x
jamesrm
 Share
For a couple weeks, my psu has been making a strange noise - it isn't the fan hitting something because the sound still happens when the fan isn't moving, however sometimes it stops when I unplug the pc and press the power button for about 30 seconds, but this doesn't work every time.
I have uploaded the video of the sound.
UPDATE: the sounds stops after about 20 mins of the pc being turned on
Are you sure that's the PSU and not the GPU?
come to think of it, it could be. do you know what might be causing it/what it is if it is the GPU?
  • 4 weeks later...
Gpu and psu both share a possibility of something that us pc gamers call coil whine it will probably be that unless it concerns you then it will be nothing to worry about most likely
 Share
